Good experience at Discount Tire
Retiredville SC
Recently received the Continental tires I ordered to participate in their rebate promotion. Normally take them to a shop I've used for years where the owner and partner are the only two who work there and do everything. They take their time and do things right. Match mount the tires (spin wheels before mounting etc.), ride balance and Road Force until all wheels/tires are in the single digits. NEVER had any damage to a wheel and every set rode like a velvet carpet. These guys are the best. Well, one of them was on vacation til early August and the owner was taking a break while the balancing and mounting machines were calibrated and serviced. Had to have the tires installed by 7/31 to get the full rebate. Didn't look like they were going to be able to handle it.
So, started looking around and had a few recommendations for Discount Tire. Called the local shop and spoke to one of the managers, Will, who turned out to be a tire nut. I went over all of the service I get at my usual tire shop and Will started firing back that he personally handles all of the customers who are like me and have concerns about doing installs correctly. Will says he has been with DT for about 10 years and specializes in the big wheel/low profile tire installs. Well, Will is apparently an install magician. He took my wheels and tires, handled them with a white glove treatment, and did a fantastic job of mounting and balancing. He also does the wheel spin prior to tire install and marks the high spots. He then rolls the tires on a rack and finds high and low spots there. Then does the best touchless mount I have seen at any big shop. Only contact are the holddowns that locate on the INSIDE of the inner bead area of the wheel. Nothing got near the face of the wheel or the rim. Zero damage. He verified the match mounting with the balancer and all were spot on. Road Forced everything and all were single digits, the highest was 7lbs. and the lowest was 2lbs. Pretty good for a 19" wheel set with rubber band 235/35 tires.
But the BEST part was when I went to pay for everything. Will had originally quoted me $54 per wheel/tire for all the service I wanted. First modification to that was he had included dismount and tire disposal, but I had bare wheels. Now it became $42 a wheel. Then he gave me a preferred customer discount and it brought it down to $37. When I mentioned that I bought the tires at Tire Rack and they were a recommended installer, he modified the price once again. $25 a wheel/tire, evidently Tire Rack customers get free Road Force at Discount Tire since both are now the same company for all intents and purposes. Will even washed all of the tire lube off of the wheels and loaded them in my car. In and out in about an hour with a perfect set of mounted and balanced wheels/tires. Think I've found a good alternative to my tried and true if need be.
Around here it’s Americas Tire but they’re always excellent to deal with. Although last time they left their lift pads sticking out the bottom of my Tesla haha. I noticed before I left. They were appreciative!
I only buy from Discount Tire but every location in a 50 mile radius of me cannot balance tires properly. I have been back for rebalancing 4 times on new Coopers on my truck within the 1st 10k miles. Same with 2 other vehicles and friends. The last 3 sets of tires I bought I had to bring back immediately same day due to balancing.
He actually used the road force feature on the Hunter machine? That is unheard of for America's Tire/Discount Tire.
When I had vibration on the Tesla they did rotate and balance. When it still vibrates they did road force no extra cost. Turns out my issue is bent wheel. I just ignore it. But they were so nice and road forced and moved wheel around to make it less noticeable all for the same price as just basic rotate and balance. Honestly can’t find a local shop that cares that much around here. Sad but true.
Discount Tire, like other national chains are highly variable on quality, based on location and current staff. One of their locations in Seattle scratched up my wheels....and Costco Seattle has as well. The only places I have had good work locally is the Ferrari dealer and the BMW dealer (as one would expect) but prices were commensurate.
I use a boutique specialist now. His rates are competitive, but more importantly, he is super careful in his work. He mostly caters to track racers and has a set up at his home. Tire Rack drop ships to his house. Or I pick up at the Tire Rack regional warehouse 15 minutes from his house.
To the ones around here, "road force" means pay attention to what the road force icons say; if it's green, they consider it road force balanced.
