Originally Posted By: Ducked
Originally Posted By: Falken
Ducked, the strength of the magnet used on the Gold Plug is absurd.
I picked up a 6" Wescott with it.
It could easily collect a gram of iron without loosing effectiveness.
It is a very good product.
Ok, mine isn't a "Gold" Plug (though I've seen actual gold-anodised oil filler plugs on scooters here - blingtastic). IIRC its "King" brand (?), and probably isn't a high-strength rare-earth magnet.
I'm still unsure whether that's such a great idea though. These particles get magnetised even on my wimpy plug, because they form "whiskers" on a paper clip.
Its seems possible that, however powerful the plug is, it will acquire more iron in static, cold oil than it can hold when the oil is turbulent and hot.
This would imply circulating
magnetised wear particles. This MIGHT be a good thing, since they MIGHT clump, and MIGHT then be trapped by the oil filter which they would otherwise go through.
OTOH, they MIGHT be attracted to other iron things, like crank and camshfts. This MIGHT promote wear.
I dunno, and if anyone else does, AFAIK they are keeping quiet about it.
Well. pretty quiet. Stumbled on this just now, the only mention I've seen of this problem, if it is a problem. Certainly I don't recall it being mentioned in any discussion of magnetic "filtration".
http://www.machinerylubrication.com/Read/781/particle-contamination
"Magnetic Susceptibility. Permanent magnets are used in some filters and online wear particle sensors. Particles of iron or steel that are attracted to a magnetic field are preferentially separated from the oil by these devices. Later, any particles that may have sloughed off these separators and sensors (due to shock or surge flow conditions) are often left magnetized. They can then magnetically grip onto steel orifices, glands and oilways restricting flow or simply interfering with machine part movement.
Additionally, directional control and servo valves commonly used in hydraulic systems deploy the use of electro magnets in their solenoids. The actuation of these valves can be adversely affected by the magnetic susceptibility of iron and steel particles that are attracted by the solenoid."
