Ok guys, I have a few simple questions. Should've used this site long ago to find my answers, I've been a member for a while now. Anyway, I've got a remote 3/4-16" oil filter mount that I'm going to be setting up for a bypass filter in my 12v Cummins. I will tap in at the oil port above the oil filter next to the turbo oil feed line. I was going to get the Baldwin B50, but after readins some of the posts here, it appears that it is not really a 2um filter. I also had the Baldwin BF797 in mind (4um). Anyone heard of that one?
I could get the Amsoil eap110 filter but it's too expensive. I got the mount and brass nipples for $25, and I'm gonna get some push-lok hose from Autozone for under $10. I wasn't planning on spending over $100 on this project, cause then i probably wouldn't even bother.
So a few questions:
1) In the end, is the B50 still the best reasonably priced bypass filter available?
2) Do you guys see any problem with running pushlok hose?
3) Will I lose oil pressure by adding this type of bypass filter mount by tapping into the oil pressure port in the engine?
4) What type of restrictor should I use to limit the flow of oil into the bypass filter so I don't lose too much oil pressure and maintain maximum filtration?
I appreciate all the help!
So a few questions:
