Originally Posted By: kenpoed
It ran smoothly and at 75 mph it lost all compression. When the shop took it apart the tensioner was stuck, the belt came off and was frayed but not broken.
The shop that performed the timing belt change confirmed the tensioner was not replaced.
The only issue the car had was ticking for 5 minuted after cold start up.after a valve adjustment and two Honda techs, the consensus was the sound was a cold fuel injector
Is the shop trying to feed you a load?
Okay, to confirm a few things; You have an 05 Accord V6, and the timing belt shredded in service. If I understand correctly, teeth were skipped or shredded throwing valve timing off and bending valves in both heads, but not broken, just shredded.
Here is your tensioner and idler.
If one were to seize, how would the toothed-side of belt sustain damage, yet the backing, of which the tensioner rides on, is left intact??
UNLESS- the tensioner was LOOSE, ie not maintaining tension and caused the belt to skip teeth.
Since the tensioner spins, being 'seized' suggests it no longer spins due to seized bearings. The only way it would make sense is if the culprit is the tensioner spring: a little spring loaded "shock absorber" that is filled with extremely viscous fluid. It is designed to expand very slowly when belt slack is present, and is not designed to go back in, but it will if it has been damaged and the engine is shut down with tension left against it.
They get damaged when someone does a TB job and FORCES the shaft of the tensioner spring back in too fast, causing hydraulic damage to the inside. I learned that many years ago, and since then have never had a tensioner spring fail, because you HAVE TO take your time compressing them.
I'd be wary of a botched job.
