Happy February! I was on my local craigslist when i stumbled up on a pretty decent looking, older lady owned 1990 Oldsmobile Cutless Ciera S. It has the same engine, and transmission as in my buick, the 3300, and 3 speed Th125C or 3t40. It only has 90K miles on it, but it was not running. I picked it up for a song and a decent conversation, and had to tow it back home. The fuel pump was bad, so replaced that along with the strainer and fuel filter. car started right up. It sounds pretty good, but has slight sludge
and valve ticks. It sounds like a modern Honda 3.2/3.5L on 0W20.. It drives really well, has a little more power then my 220K buick, and has no rust... Alright now the issues i am having is the torque converter does not seem to engage all the time when it should above 35MPH. I also have a Code 26 sometimes... I changed out the fluid and filter with maxlife and it made a decent difference in the way it shifted/downshifted. When the TC does lock it is silky smooth, and some times will lock and unlock and work 100% normal for miles, so i dont think its a mechanical issue. The transmission shifts pretty good, slightly firm under real hard throttle, but nothing over the top.
Next issue is the idle seems to really be high. I can almost putt along at 30 MPH and not touch the gas. If i put the car in neutral while moving under 5MPH it will rev up to 2K rpms, then slowly come down. the buick does not do this under the same conditions. Even to start it up it seems to rev higher then the buick. When slowing down to a stop with the car in drive i would say the RPMS are 200 higher then normal, or in comparison to the buick this car kinda pushes you more with out giving any gas.
I would also like to clean out the engine alittle. I want to say it has about 22Oz of sludge in the engine total as it takes that much LESS to fill over the buick.. I put in a 1/2 QT of mmo and ran it for 350 miles and changed the oil to MAxlife 5W30.. But this engine might need a little more then maxlife. I think its ticking due to lack of oil on the upper valves or something. Because after i give it a real good spirited drive, ticks go away.. Im thinking of going with a 10W40 maxlife or a diesel 15W40 and then putting 32OZ of mmo in with 3 1/2 Qts of 15W40..
What would you guys suggest i should look in to, so i can fix these issues? Thanks much!! Cheers!.
