- Joined
- Dec 7, 2012
- Messages
- 3,560
Sitting here thinking — the new Gen VI small block that’s coming out. Inevitably will have AFM to meet CAFE requirements.
Wonder if a design such as a two-piece rocker arm would ever work. Rocker arm having one pivot point near the pushrod and another in the usual location with the trunnion. Utilize a system like a Honda variable lift where a hydrauliclly actuated pin locks the entire rocker arm to operate that valve when in V8 mode.
When not in V8 mode, the back half of the rocker would just pivot and go along for the ride.
Standard lifters in every lifter bore. Valves would stay closed when the cylinders not commanded. Of course cut fuel and spark to those cylinders. Oil would still travel through those lifters, and up through the push rod, even if that cylinder was deactivated, I don’t think from an oiling standpoint it would matter much if that extra flow was in the head.
Seems to me if you could keep potential failures to under the valve cover, you’d have a lot less of a headache when a failure occurs.
Wonder if something like this would ever work.
Would be sweet if Gen 6 had windows in the valley to change lifters.
