Yes, A substitute or anything that’s works.Are you asking for a suitable substitute?
Appreciate the information…. ThanksPrestone yellow bottle. I use it in my Chevy truck and it can be found most anywhere.
Can you elaborate? Which GM models does this apply to? Thanks.GM recommended Dex VI for cold operations. I no longer blow out power steering hoses in the cold.
Thanks for the informationNAPA has power steering fluid that is supposed to meet the GM requirements: https://www.napaonline.com/en/p/PSF9832?impressionRank=3
How would the universal DI package affect your power steering system?...I decided to use the AC Delco brand since I didn't want the universal additive packs affecting my car.
I would go off color. Red=top off with Dex 3, Clear(ish)= top off with psf
Then he needs a full fluid change and to go with the fluid of his choice.What if it's black with white chunks floating on top?
