Any new news on this issue?
I took my car ('02 Z28) into the dealer for a listen to my "knock" several months back and got a "that's normal" for this engine and an explanation on shirt skirt pistons and how this phenomena(sp?) occurs.
FWIW ... my "knock" noise is definitely more noticeable in winter months and has seemed to disappear with the warming temperatures this spring/summer.
I've also noticed (last 2ea oil changes) that the "knock" noise was significanlty louder at startup after oil change than what I've heard in the past. All I've done differentl is to ensure engine oil was hot because I was sampling ... I think this may have impacted the oil pump's prime some how(fully drained when oil hot) making it harder to reprime with the new oil.
Typically I do not fill the new oil filter prior to installing it ... I tend to floor the gas pedal(cuts all fuel to the injectors) and turn the motor over a few moments to fill the filter prior to starting. I'll be pre-filling the filter from now on since I don't like what I've heard the on the last two changes.
Once oil pressure is established on the gage the noise is still there ... does not disappear until I rev the engine to ~2400rpm for 5-10sec ... once noise is gone I drop back to idle and the noise does not return. What I find interesting is the fact that if I don't rev the motor to ~2400rpm and just let it idle after oil change the noise does not go away and is very pronounced until engine rpms get up from either me driving it or reving the motor.
I don't view this "behavior" as normal ... although it may be "normal" for this motor nor do I believe it will noticeably shorten my engine life but I'd like to hear any comments or thoughts others may have on my particular issue as it relates to this thread topic.
Thx JHH
Link to my M1 0W40 oil analysis
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=001469
Link to my M1 10W30 oil analysis
http://theoildrop.server101.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=001096#000003
[ April 30, 2004, 11:33 AM: Message edited by: Jared H ]
