Terry,
As I mentioned on the other 2 threads; someone mentioned about a TSB on these pumps. The guy stated a faulty o-ring that caused cavitation and excessive noise from the pump.
I also think that the "Piston Slap" problem might be a bit overblown by the enthusiasts. I think "most of them" have been blaming the wrong thing. Don't get me wrong, these cars DO suffer from cold start slap, but I'm betting many of the "slappers" are actually suffering from bad pumps.
I'd go out on a limb and give my expert opinion
and say that at least on Chris' engine as well as mine, the piston slap should not affect durability since Al is very low and iron is relatively low for these two large engines, besides the fact that at least mine was driven hard!
I have also had the chance to listen to some of our pick up trucks at work and they also make the valve clatter noise, although much less noticeable. Do P/Us use the same pump type?
These pumps obviously need more investigating as it seems more and more they are the cause for the high copper and "diesel engine" sound.
Rick
Rick
