"Why the LT2 Avoided the L87’s Recall Issues
• Manufacturing Window:
The L87 recall is tied to a specific production period (March 1, 2021–May 31, 2024) with defective components from suppliers.
The LT2, produced for the lower-volume Corvette, likely used different batches or suppliers, or benefited from stricter quality control. GM’s 2025 L87 engines are also exempt from the recall due to manufacturing improvements, suggesting the LT2 may have been built with similar or better processes.
• Oil Viscosity: The LT2’s use of 0W-40 oil from the factory aligns with GM’s recall remedy for the L87, indicating that higher-viscosity oil
may reduce bearing wear. The L87’s initial 0W-20 specification may have exacerbated issues in defective engines.
• Application Differences: The LT2’s dry-sump system and performance-oriented design reduce stress on components during high-RPM operation, unlike the L87’s wet-sump system, which faces different load patterns in truck applications (e.g., towing).
• Production Scale:
The Corvette’s lower production volume (tens of thousands vs. nearly 600,000 L87-equipped vehicles) means fewer opportunities for defective components to affect LT2 engines, and GM may prioritize quality for its flagship sports car.
Conclusion
The LT2 V8 in the 2025 Corvette differs from the L87 V8 in GM’s recalled trucks and SUVs through its performance-oriented design (dry-sump, shorter intake runners, higher horsepower), use of 0W-40 oil, and apparent exemption from the manufacturing defects affecting L87 engines from 2021–2024.
The L87’s recall stems from faulty connecting rods and crankshafts, leading to engine failures, while the LT2 has no reported similar issues, likely due to different production processes or quality controls. Owners of L87-equipped vehicles should check their VIN on GM’s recall lookup website for inspection and repair details, while Corvette owners can rest assured the LT2 is unaffected by this recall."
https://www.corvetteforum.com/forum...921439-6-2l-engine-recall.html#post1608776331
