GM aborting move to 0w-40
When I was in the fleet business we had a couple of Chevy 4.3s that snapped the starters off the block. The fix was a new block. If I remember correctly, it was due to a faulty cam position sensor when it got hot. The motor would try to fire when it shouldn't have (confused by the faulty CPS) and cause a kick back while the starter was engaged, snapping the starter and mounting ears off the block. Someone said way back when, but it was never verified to my satisfaction, that block casting was made lighter and there wasn't enough material where the starter mounted.
As I said earlier in this post, this is a lower rod bearing failure. Although I'm not a xw-20 fanboy. this is a very rare issue HTHS will not fix.
The 6.2 L-87 makes 460 lb ft of torque. It just doesn’t seem to be the engine to run a 0w20 motor oil. My 6.0 LY-6 makes 383 lb ft of torque and spec’d 5w30. I have been running 5w40 in it for last few years.
There’s no way I would run 0w20 in the 6.2L LT1 in my Corvette (which makes 455hp/460 lb ft) I wasn’t even comfortable running vanilla M1 5w30 with its weaker 3.1 HTHS, which is why I chose ESP Formula 5w30 right away, I think these engines need a 3.5+ HTHS oil.
Some random issue seen when rebuilding are: excessive or inadequate bearing crush, inadequate big end side clearance, excessive fillet or rounds at journal margin (also missing bearing chamfer), positive deck + thin gasket, Stuck IE valve(s), excessive cam advance or retard vs blueprint, incorrect pump bypass spring, leaking or missing gallery plug(s), piston/pin offset 180 out, and again, machining/polishing debris in crank or block galleries causing oil starvation or bearing streak.
have any teardowns evidenced bent valves? Arco.
The 6.2 L-87 makes 460 lb ft of torque. It just doesn’t seem to be the engine to run a 0w20 motor oil. My 6.0 LY-6 makes 383 lb ft of torque and spec’d 5w30. I have been running 5w40 in it for last few years. The 6.6 L8T specs 5w30. It’s crazy that GM is digging in it’s heals for 0W20.
I mean, the 5.7L HEMI makes 410lb-ft of torque and it doesn't seem to have any issues on an xW-20 🤷‍♂️
Kind of weird writing in that first paragraph.
I’m not understanding what is weird🙃
Maybe the word “finally”?
The reason for that would be I initially got a letter from GM indicating there would be a recall however, the parts are not in stock yet, and they will notify me when they are.
Once I got that letter, I admit it’s been sitting on my desk for months now however I’ve been under medical treatments, almost daily, and now that things are settling down, I plan on getting to it
As my old boss used to say, "ISO 9001 just ensures it's consistently done improperly"
So you had ineffective manufacturing engineering and a boss who would not drive improvement. It can take an effort and discipline to get and then do things right. I might ask does the modern world really care anymore?
https://www.amsoil.com/p/amsoil-signature-series-0w-20-100-synthetic-motor-oil-asm/
I am just wondering if all of these GM Vehicles had been using the oil I Linked, if there would have been any issues? I do not know what the OCI's were on these vehicles or if the owners checked their oil level. I am willing to bet that even if these owners were using Redline 0W-20, the good stuff, not the cheap stuff, we might not be seeing these issues.
