Originally Posted By: NHHEMI
Originally Posted By: steve20
""" Originally developed for the Corvette as the engine bay was too small for an oil cooler """
I don't think so----cost was the reason behind the decision to not install oil cooler at the factory
No, it was because an oil cooler would not fit in the engine bay. At least for the Vette. The info is out there about it. An oil cooler cost the mfg all of $20. The cost of an oil cooler, if it was needed, would not be a deciding factor in a vehicle like a Vette.
NHHEMI, I was under the same impression. All the tech articles I've read indicated that oil coolers are a weak link in an oil system and that's usually a trigger-point for leaks. GM decided if they could get away from having to plumb a cooler by using an oil that would withstand high track temps it would be better for all parties. Surely cost savings are an added bonus, but on the flagship of GM's vehicles, cost is not normally a big stumbling block.
