******************VERDICT*******************
Timing chain cover gasket...(go figure)
Mechanic said that there is a section of it toward the top that has an antifreeze bypass of some sort and that is what is causing the coolant leak. Said he will also check the timing change, but suggested that at 130k, it would be a good idea to replace the chane since they will have the cover off. Also said he will have to give the egine an oil change as gunk will get into the oil from doing this job. Regarding the oil change...After they change it, would it be a good idea for me to change the oil again after 500-1000 miles to be safe as to make sure any additional stuff is drained out from doing this repair?
