To Syn or not to Syn, that is the question :)
midwest
I have a 2000 Dodge Gr Caravn, and I Have a 1995 Chev Lumina. The Lumina has a bit more oil seapage than the Caravan does. The Caravan's engines is complete dry except for a small bit of moisture around the oil pan gasket... Dodge has 67k, and the Chevy has 127k.
Is it true what Advance Auto tells me that I will not hurt a thing by putting in synthetic? Does synthetic like Mobil 1 have any seal conditoners in it?
It's true mossad, run synthetics at your will. If you want a seal conditioner, use a oil like Valvolines synthetic Maxlife oil. Look through the deal section at the bottom of all the different forums...it can be had after rebate for cheap. I would run 10-30 in both.
http://www.valvoline.com/qrz591dpoyu/step1.asp?rc=185F7C1128&coaid=1079134EE68
If your engine is dirty, I would Auto-Rx it first. Otherwise you may cause a debris-shift of nasties inside in your engine that a synthetic may loosen - due to it's higher detergency.
Some engines do fine undergoing the switch -- other will begin to clatter because they weren't well maintained. We cannot see inside your engine -- so every opinion here is either a blind guess - a recommendation of what worked for someone else - or a cautionary amber light.
quote:
Originally posted by mossad:
Is it true what Advance Auto tells me that I will not hurt a thing by putting in synthetic? Does synthetic like Mobil 1 have any seal conditioners in it?
Yes, it's true. You can switch to synthetic oil at any time. As far as synthetic oils having seal conditioners, they all have some, but it's primarily there to balance the seal-drying effects of other additives. If you suspect you have some dried/hardened seals, then use one of the "higher-mileage" oils. They are formulated to be at the thicker end of their viscosity rating and contain extra amounts of detergent/dispersants and seal conditioners.
Will you run the syn long OCIs? If not
I wouldn't use it anyway. And to syn or not to syn is academic if you remain a 3K OCI guy.
I switched to Amsoil from conventional in my Ranger with 80K miles on it with no problems (actually runs quite a bit better). I would have run an ARX cycle first had I known about the product before I switched though. That should really help with any seal concerns.
quote:
Originally posted by KieferS:
i use mobil syn blend and change it every 2999.9 miles.
I could see 2999.1, even 2999.2...but don't push your luck by going to 2999.9. You'll lose all the blinker fluid!
use syn if:
1)you are not leaking oil. Syn's smaller molecular makeup = more leaking oil. I say this from personal experience)
2)like to save the environment just a little
3)would like to change your oil half as much
4)like the idea of a viscous fluid that's slicker than snot on your internals
""If your engine is dirty, I would Auto-Rx it first. Otherwise you may cause a debris-shift of nasties inside in your engine that a synthetic may loosen - due to it's higher detergency""
is that not what RX is suposed to do??
bruce
ah true...
As an aside, I've never seen synthetic alone dislodge massive amounts of crud without some help...from a solvent.
Hehhehe- Yea man,don't wanna burn out the blinkers. On a side note- my aunt who works at walmart tells me there is a 5 quart jug of M1 on sale for only 14 dollars today
Im gonna go buy ten quarts now.
