GM 1.5L Turbo - Help Me Pick an Oil!
That's the plan. No maintenance history on Carfax but what I can see from the oil fill hole looks clean. GM's severe service for the transmission is every 45k, lifetime fill for standard service.
I plan on doing two spill and fills with some Valvoline Dexron IV to get rid of what is in there, probably the factory fill. Then I'll do a couple with HPL's ATF-Green. Bought a case for the Mazda that got totaled, lucky me it uses the same HPL Green.
I'll probably do all the fluids this weekend. I've got some Mobil 1 Synthetic 75W-90 already for the rear diff and transfer case.
Coolant and spark plugs will be next in the coming month or so.
You are going love the oil change so easy filter n drain plug right in the front no obstruction to the filter. I don't even jack it up put one tire on the curb.
My wife's 2018 1.5L Equinox is approaching 76,000 miles and all I have done is use whatever 0W-20 is on sale and change it between 5-6K miles, and most of the time I use regular 87 octane. Most of the trips on that car is highway though. She works from home so most of those trips are to the cabin and back.
I just did first oil change on GMC terrain used OE filter and Kirkland 0/20 caught on sale but mostly short trips changed OLM hit 5%. Bizzare thing AWD takes 5.3 qts FWD takes less If I remember correctly 4.2qts
  • Like
Reactions: JTK
Will that raise the octane rating?
No, but it keeps the combustion chamber cleaner, and the deposit will be softer. Take into consideration that the turbo has a lower compression ratio, so there is no need for high octane; however, premium fuel has more combustion energy anyway.
Thanks. It can provide for a more efficient extraction of the energy (if the engine can compensate), but the total BTU content of the two will be the same.
It gets a bit complicated when you consider how the octane rating is achieved. Using EtOH will actually reduce the total energy of the mixture while raising the rating.
I wish auto engineers would make sumps that take exactly 5 or 6 quarts. My Toyota V6 is supposed to take 6.4 qts but I dump in 6 and the dipstick is at the full mark. The Chevy 1.5l is hilariously small at 4.2 qts.
It’s not bad at all. The only thing is getting the fill cap off and a funnel in without burning your hands off. Thus, do it cold 😂.
If you un-clip the ECU out of it's holder and flop it out of the way (still plugged in), you gain a bunch of room to reach in for the ATF refill cap on the 2018+. Just use caution around the plastic clips. I snagged one on my sleeve and snapped it right off. Either way, you still need a funnel with a hose or very long, thin spout to reach the hole for the re-fill.
4.2 quarts is about average I'd say. My old Nissan sentra was less than 3 quarts. That, was disappointing.
Back to your question about which oil to use, I'll go for M 1 ESP 0/5W-30. For my 2020 2.0 GDI this what I use. In fact, it recommends 5W-30 oil, which pleases me. Most of the time I use Shell midgrade and it seems to work well for me. Hope you have a long happy ride with your Equinox.
4.2 is for FWD 5.3 qts for AWD which is confusing both the same 1.5 turbo 4 cylinder. I will say I just put in 5 qts was at the full mark or close enough
is that toyota a 2.3 V6 or smaller? If not it actually has a smaller sump vs the the size of the engine. And that matters, there's more to lubricate, more to seal, and more contaminants making it into the oil. I don't consider 4.2 quarts hilariously small, but wouldn't like it any smaller either as when the oil level falls to minimum it barely got 3 quarts in it.
That one is a stumper for sure as they use the same engine and the transfer case on AWD models doesn't appear to impede or make the engine have to be any different in any way. I don't know that I've ever read of a 2018+ FWD version owner confirm that 4.2 is indeed all it takes. Hopefully someone here can confirm.
My 2021 1.5, AWD takes about 5.5 qts to put the oil level more towards full mark.
No- 2GR-FE 3.5L.
I have a 2021 'Nox 1.5 AWD. The AC Delco PF-64 holds about 0.2 qt. I pre-fill the oil filter, then dump in a full 5-quart jug. Perfect!
I love the forward-facing drain bolt! The engineers were thinking about maintenance.
I have a 2020 Equinox LTZ-V (Australian), with the 2.0T LTG and 9AT / AWD - currently ~107,000 kms. Also a 2017.5 Holden Astra BK 1.4T 6AT with ~140,000 kms with essentially identical engine oil requirements.
Agree with the comments about ease of serviceability of this car, I've done several oil changes already, several drain and fills of ATF, and replace the Xfer case and diff fluids and none of it was hard at all.
Being in Australia, I've tended to go with local oils, such as Nulon Apex+ Long Life 5W-30 (Dexos rated), with a typical OCI around 6000-7500km (~3700-4700 miles). What I actually do is reset the oil life indicator when I do an oil change, and change the oil when it's in the circa ~35-50% life remaining and I have a convenient opportunity within that window.
Over the past week or so I've been reading a heck of a lot about Valvoline Restore and Protect, and I think this is what I might be going with moving forward now. The cleaning properties seem legitimate, keeping the rings in good order is a massive plus long term, and from what I've read it's been confirmed with Valvoline more than once that it meets/exceeds Dexos1 gen3, it's just not certified (perhaps if only to not give away their unique additive package that achieves this cleaning). Neither vehicle seems to consume any oil between OCI's and I'd love to keep it that way.
Honestly it seemed to good to be true at first but there is an overwhelming amount of data/stories now showing it really does what it says on the tin.
I still have a few of jugs of the Nulon Apex+ to get through as I tend to buy multiple when they're on a good special, especially as the same oil suits both my vehicles, but I am really looking forward to running multiple consecutive Valvoline Restore and Protect OCI's to see that cleaning in action and get these motors clean on the inside. For piece of mind I'll likely have both vehicles intake valves professionally cleaned to 'reset' them and with with VR&P hopefully these motors will last a very long time.
