B byez Joined Oct 21, 2007 Messages 434 Location Canada,North America,Western Hemisphere,Earth,Milk May 30, 2009 #1 My 08 Tundra calls for either GL4 or GL5. Which one is better suited to the job? The front & rear diff call for GL5 specifically.
G Gary Allan Joined Sep 28, 2002 Messages 39,793 May 30, 2009 #2 I'd say it depends on how many fluids you want to carry. Amsoil's site confirms that both are spec'd for the t-case.
Shannow Joined Dec 12, 2002 Messages 43,980 Location 'Stralia May 30, 2009 #3 Transfer cases it don't matter. They oft spec ATF in them, when they are the same as the manual transmission. If your gearbox is GL4, then use that.
U unDummy Joined Feb 1, 2003 Messages 8,755 Location RI May 30, 2009 #4 I would use a GL5. In rarely maintained transfer cases, any added protection will help. I've seen too many gear, bearing, bushing, chain... failures in transfer cases. Use the best fluid always.
M mechtech2 Joined Sep 5, 2006 Messages 19,478 Location Chicago Area May 30, 2009 #5 Using the GL5 sounds good there.
