GL4 vs. GL5 - Toyota Transfer Case
I'd say it depends on how many fluids you want to carry. Amsoil's site confirms that both are spec'd for the t-case.
Transfer cases it don't matter.
They oft spec ATF in them, when they are the same as the manual transmission.
If your gearbox is GL4, then use that.
I would use a GL5. In rarely maintained transfer cases, any added protection will help.
I've seen too many gear, bearing, bushing, chain... failures in transfer cases. Use the best fluid always.
