You took out the query string! Thank you!!
????????????????Typically inverter generators only spin the engine fast enough to supply the power needed at the moment. they idle down under light loads and speed up under higher loads. This Genmax unit is not doing that.
Flip through the video. In every shot of the generator, it sounds like it is running at the same RPM. Even the stickers on the unit say 3600 RPM. When the AC unit in the guy's RV kicks on, the engine speed does not change. It seems that this generator is really just a quiet version of a construction generator.
I guess the benefit of this unit is the noise reduction. I don't see this saving very much on fuel.
If you look at 4:44 in the video the thing clearly has an Eco mode switch. I don't know, but it may be possible that it was tested with Eco mode off. In that case it would run continuously at 3600 RPM. That's my theory...Typically inverter generators only spin the engine fast enough to supply the power needed at the moment. they idle down under light loads and speed up under higher loads. This Genmax unit is not doing that.
OK. I missed that at 8:00. It did rev up and down.????????????????
8:00 and 12:45![]()
Maybe.If you look at 4:44 in the video the thing clearly has an Eco mode switch. I don't know, but it may be possible that it was tested with Eco mode off. In that case it would run continuously at 3600 RPM. That's my theory...
