Does Unload mean unplugging appliances etc. before turning off the Generator ?Most gens say to unload them before shutting down. I'm sure many have run out of gas while fully loaded even with the best intentions. Other than timers, watching the gauge, etc does anyone have a better idea?
yes; any generator should not be started or stopped when under electrical load.Does Unload mean unplugging appliances etc. before turning off the Generator ?
I agree. Although the after an ice storm this past winter, my genset stalled because of a clogged fuel filter, while powering my home. Thankfully everything in the house, as well as the generator, was fine.yes; any generator should not be started or stopped when under electrical load.
No doubt your generator transfers at full rpm . Different situation .My Generac is propane fueled and hard wired to my main electrical panel. When the power goes out it automatically starts up and when it senses the power has been restored it shuts down. In any of those cases there is some load present, with the possibility of the furnace or AC unit running. Otherwise the load is probably small from my energy efficient appliances and LED lighting throughout the house.
So I assume that the Generac has some kind of circuitry to handle the load situation when it cycles. It may be quite different though for inexpensive emergency gasoline generators so I'd probably contact the manufacturer for guidance.
I don't think it's that big of a deal. There are a lot of people in this country who live off of very undependable electrical grids. They face power failures and brownouts on an almost regular basis. I don't think they buy any more air conditioners and refrigerators than anyone else.I think the danger is to the items plugged in and the surging more than the generator to be honest.
I just have gotten use to how long my generator goes with my RV. I can make it all night on a tank so I don't worry too much about it. Some of the newer ones have Bluetooth gauges if you look.
Just my $0.02
