Greetings!
I have an older (I think from 1995) Majestic Ventless Fireplace. Since I moved in I did not even try to see if it worked. I just tried today and it worked! I just have a couple questions. Does anyone know if you can change the flame size to the pilot? I have to manually light the pilot. It starts fine but when lit it sounds like a blow torcher and looks like one. Wasn’t sure if I can tone it down a tad. The log set is a Majestic Log model VL21.
Couple more questions I promise (sorry I am such a newbie on this)
1. Is it normal to smell gas when it is lit? There is no smell when it is off, just when it is on. After awhile it can get alittle overbearing.
2. Is there a specific distance the actual grate and logs should be either from the front of the fireplace or back? Or I guess, how do I know if I have it positioned right inside of the fire place?
3. Last. I have a Donte Log Ignitor Valve in the wall on the left side of the fireplace. Turning the key to the left is "open" and turning it to the right is "closed" The key now, is as far "open" as it can be. However, when I try to turn the key to close it, it just keeps going. When I keep turning, to me it feels like it is getting looser and looser. I am afraid to keep turning it and break something. I take it that is not normal right? Would/Could that be a DIY Project?
