Originally Posted By: Hot_Ajax
Thanks for responding. Question: What does "VI" mean, where you wrote that "synthetics won't have much if any VI". Not sure what VI means. Thanks.
VII's are known as polymeric viscosity index improvers. They are added to an oil formulation to allow a finished oil to have a higher apparent viscosity at operating temperatures, but still retain good cold flow characteristics by starting off with a thinner base oil.
To explain this another way, in a conventional SAE 30 oil, the oil only has one main requirement: it has to be between a certain viscosity range at 100C (212F) (9.3 to 12.5 cSt for a 30 grade oil). Thus, a formulator would choose a base oil that would fall within that range when heated to 100C.
However, when looking at multi-grade oils (such as 5W30 for example), these oils have to meet additional requirements. The 30 means that it still has to be between 9.3 to 12.5 cSt at 100C, but the 5W implies that the oil must not exceed 6200 cP at -30C (-22F). So any oil with a W in the grading will have an additional cold specification to meet as well as a hot specification. In order to formulate a 5W30 in a conventional oil, a blender must start with a thinner base oil, and use viscosity improvers (VII's) that allow the base oil to thin out LESS as it's heated when compared to the same base oil without any VII's. Thus, you can start with a thinner oil for good cold temperature properties, but still end up with a finished product that will fall between 9.3 and 12.5 cSt at 100C.
However, the trade off is this: VII's can and do break down under extreme use, and thus an SAE 30 grade will be more robust in those particular cases where a 10W30 or 5W30 oil may break down, leaving you with an oil that is below 9.3 cSt at 100C.
But in the world of synthetic oils, the base oils used have a naturally high viscosity index (a measure of how much an oil thins as temperature increases). Thus, a synthetic oil can use a lot less VII's (if any) when used in formulating a multi-grade oil. So where a conventional 5W30 oil may have a certain percentage of VII's, a synthetic will have next to none, if that. Also, the quality of VII's used also determine their performance and longevity under extreme conditions as well, so a premium product may use better VII's than a no-name brand (for example).
What this means in terms of your generator... If a conventional SAE 30 is recommended, it is to avoid the issues created by VII's in this particular case. An air cooled generator engine can run very hot under heavy load and in hot weather, so an SAE 30 is a safe choice for the manufacturer. But, if you decide to use a multi-grade oil, a fully synthetic 5W30 would likely stand up to the heat even better, but would also give you better flowability at room temperature and below (down to very cold temperatures).
Hopefully that helps a bit. As I said, I use synthetic 5W30 in my generator and other power equipment.
