Both AWD 14 Venza-120k mi and 21 RX350-17k mi call out Toyota LT non-slip gear oil. On the Venza, I have always used Mobil 1 Delvac 75w-90 with 5% Red-line friction modifier added which would make it closer to the Toyota LX limited slip gear oil. Delvac has zero limited slip additive. So far the Venza has received three transfer/rear differential oil changes with no known issues, chatter or unusual noise. It seems to run very smoothly.
Most synthetic gear oil on the market are considered limited-slip and one the reasons for making the Delvac+Red-line was cost ($30/gal) and general compatibility.
On the 21 RX350 was is the recommendation? Considering that both Venza and RX350 do not have the same transfer case/ rear differential, do I do a) or b)?
a) delvac + 5% Red-line
b) delvac and no additives
Maybe I am over-thinking this? Lol
