Originally Posted By: PT1
Try the redline shockproof heavy
+1
It's a 75W-250 that is said to flow like a 75W-90. I've used it in our two '07 Big Twins (6-speeds) year-round with no shifting problems whatsoever. Seems consistent when hot or cold.
I drained out one of the gearboxes last weekend after 5500 miles and the magnetic drainplug was spotless and the oil looked new.
Same here. The tech at redline said you can run it 30,000 miles.
I don't doubt it. I just changed my transmission's Shockproof Heavy last week, and while it only had about 5500 miles/8 months on it it came out like new. (Pepto Bismol in, Pepto Bismol out.
The drainplug magnet was spotless too- no metal at all. I've heard of many who leave it in for 20k miles with the same results.
I only drained it out to try Spectro's Platinum 6-speed gear oil as they advertise it specifically targets the whine inherent to the new H-D 6-speed.
After running it for several hundred miles all I can say is- stick with the Shockproof. The Spectro did no more to squelch the 5th gear whine my tranny has than the Shockproof did. That's not to say that the Spectro is a bad oil because it's not, but for what it costs compared to Shockproof ($18 per qt for Spectro, $12 per qt Shockproof) it simply offers no advantage.
I'll leave the Spectro in for a year or so then change back to Shockproof...
