GM seems to recommend 5w-30 for their Vettes, all around, unless the temp is over freezing(like in warmer weather)you could use 10w30, as an option. Which I use. The most important thing is that the oil, usually a synthetic, meets the GM4718M code. You will see that code on the container, if that oil is up to specs. If you do anything else, check with your dealer, or you may have warranty problems. My Vettes run, usually 205 degrees, unless they sit in traffic, then it could go up to 225+. When Vettes run fast, they actually run cooler, they're bottom breathers. If you run that high, you may have a cooling problem. I also have an '85 with an oil cooler, hardly ever gets up to 180 or so.
