GC 5k miles in GM 3.6L DI
Southern Ontario
(Previous run was Petro Canada (PC) 0W30 for 4400 miles)
GC replaced by HDEO Esso XD 0W30
How's fuel detected?
PC>GC, JMO. PC produced about the same numbers while dealing with fuel.
GC did do a 'bit' better, but the numbers are almost a wash.
Visc. and TBN were definetly better; so I'd be more comfortable with an oil like this in there.
Will be interesting to see how XD-3 compares....
Seems like an awful lot of iron in both cases, especially for 5k miles.
I think there was ONE of these engines that actually had a (more or less) normal UOA. It was so strikingly counter to what we consider typical for this engine that I pondered if the other units we've seen need some reflash of the ECM/PCM.
What did the OLM read?
Even though GM engines often show higher metals, what benefit is there in DI engines over ported FI if there is more fuel delution?
The GC did much better in regards to sheering and TBN. But wasn't the previous run a Winter run and the GC a Spring/Summer run? That might be a big factor with fuel dilution and TBN. I would think 0W30 would be a poor choice outside of cold winter operation and for short OCI. The fuel dilution and the intake deposits of DI engines seems to be due to VII, so a 5W30 or 10W30 synthetic might fair better.
We're probably entering into a neo Dark Ages like we had in the pre-catalyst 73-74 pollution control methods. Idle mixtures were richened up and Air Injection Reactor pumps were installed. Nasty time for (I think) SE oil.
I believe we're seeing the same thing here, except with catalysts.
Originally Posted By: Colt45ws
In what way? TBN is toast. Visc is deep into SAE 20. GC did a lot better.
Be interesting to see how GC compares to an HDEO in this app.
PC was a winter run. 2.3% fuel according to his blackstone report. TBN and viscosity held up better because GC didn't have so much fuel in it.
For sure. But might it be the case that some of this iron is residual from the previous higher iron count from the immediately preceding OCI?
Looking at the glass half full, no wear #s went up as compared to the previous OCI even though there were approximately 600 more miles in this interval.
As well the lack of shear this time is promising. If I look at a UOA from a similar period a year ago there was significant shear with just trace fuel detected.
And finally TBN held well with the GC.
Originally Posted By: cp3
Still going to try Duron after the Esso?
Nope. I am confident that the XD is at least the equal of the Duron.
Comparing GC to the previous fill is ridiculous. That previous UOA was not just a "trace" of fuel. That was serious fuel dilution. I wish there was a flash point for both.
So you're going to stick with the XD-3 after this?
Any warranty concerns?
I think you are right. Another example of engineneering gone astray.
XD is in there now. I have lots of 'warranty approved' oil in my stash, with receipts, to allow me to sleep at night.
340 for the Petro Canada 0W30
385 for this run of GC
