i use to have a 3rd gen rx-7.these are my thoughts.
stick to a grp 3 oil!,...that is not partly mixed with PAO or esters.
the oil being injected in the engine must burn and it's better if it does so cleanly in order for you to achieve maximum reliability and avoid failure.
ignore racing teams recommendations unless your engine is built exactly the same way.many of these teams use special carbon apex seals(about $3000 just for the seals,last time i checked)and other mods.ignore companies that tell you to use synthetics unless they can assure you they use nothing but grp 3 as base oil.it doesn't matter who swears all up and down,left and right,unless mazda is telling you there has been redesigns that allow you to use ANY type of synthetics,stick to grp 3 oils. it doesn't matter if you or someone else is using PAO/ester and is not having problems......yet.
you are doing 3k OCI.what do you care anyway?take advantage of this and save money. it took me a long time to get used to this because i am a true believer in synthetics of high quality.
the second thing that most people ignore,besides the proper oil choice,is carbon build-up.piston engines must also deal with this but on rotaries,the relationship is a little different.believe it or not,i little carbon build-up actually helps with compression,maximum HP and fuel efficiency.the problem is that too much carbon build-up,can mess up the apex seals. on the newer rotaries there has been yet another redesign to the apex seals which lessens this want/need.
the third thing some people ignore,is the proper A/F ratio or mix.it's not that rotaries are weak,it's just that rotaries with there apex seals are a bit more sensitive to detonation. what's the first thing that kid-racer across the street does when he buys any performance car?....usually,it's an after-market exhaust. on the 3rd gen cars,imediately,the turbo boost goes up(same thing happens when you add high octane,like 103)and bounces off until the computer/sensors bring the boost back down and the timing. you need a controller if you want to add more boost and in conjuction to up-graded injectors.the stock 3rd gen injecters where made to handle about 16lbs boost,no more.
the problem is that after bouncing off a few times nothing may have happended....OR,possibly catastrophic failure.
the forth thing ignored is the side seals.oil temperature is critical to these.imo,an oil cooler is mandatory,even if your just sitting in traffic.i forget what the max temperature was for long life of the side seals.i think it was 230F.
don't worry about a bit of normal fuel dilution,unless you have too much or a known problem and if you do,take care of it.
you have already taken care of most of these things,i think,and are probably aware of most of them so please don't feel insulted if i post all this.
here was my routine with my 3rd gen rx-7 with a stage 1(complete dedicated,to specific max 14lbs boost,computer,..boost controller,..complete full exhaust,no cats,three silencers,including downtube,..intake tube with huge filter,no box,properly separated for cool air only).i would walk into what ever auto parts store and buy the best quality grp 3 oil i could find and OCI at 3k miles with filter. i would alternate between shell v-power and chevron techron so as not to allow too much carbon build-up(including from the two carbon deposit cleaners themselves)and once every two years or 20k miles,i would use seafoam at 1/4 the amount seafoam tells you in the fuel tank and oil,run for a few days,right before i was doing a OCI. i would also dump about 4 oz of 2-cycle mix into every full tank fill-up.
oh,and i used 10w-30 even in florida.i just lived with the fact that this was the best oil for this engine.
i never had a problem,..stone cold reliable.
by the way,i dusted a heck of alot of cars with it,including the latest mustang GT and the brand new(for back then)400HP corvettes(automatics even more so) even though my rx-7 was much older.
..but i don't really care about being a boy-racer too much any more.
i hope this helps and changes your mind about your oil choice,.....you definately don't need PAO/ester in this application.some PAO/ester oils are really tough with high FP and low volatility and will resist burning off more so.great in other cars but not rotaries.sometimes an up-grade is actually a down-grade on reliability. the specialized mazda rotary oils are more than likely just grp 3 with more specific additive tuned for them,...over priced if you ask me.
