Can you give some examples of mineral 0w-30 oils?
Not many are made, but it can be done. Pennzoil Platinum 5W-30 is actually a 0W-30, and the 5W-20 is actually a 0W-20. They list the CCS for both of them at -35, when most 5W oils are listed at -30, and their numbers are -35 are both lower than the maximum allowed for a 0W oil. They do not list the Maximum Low Temperature Pumping Viscosity at -40, which is what 0W oils are tested at. Instead they show them at the standard 5W temp of -35, but both oils are low enough in viscosity at those temps that they should easily be below the maximum allowable of 60,000cP at -40. The 5W-20 is 9,700 and the 5W-30 is 14,800.
