Gas Residential Water Heater
northern Alabama
I am looking at propane water heaters for our new house. I am considering the power vent models from Bradford White, Maytag, Rheem/Ruud, and Lochinvar. However, the Bradford White is ~ $1200 for 48-gal and ~ $1300 for 65-gal. The Rheem/Ruud is ~ $1000 for their 50-gal. I haven't received pricing back yet on the other two manufacturers. This is pretty expensive IMO and gets me a lot more parts to fail such as the blower & the relays to tell the blower to turn on when water is required from the storage heater, etc.
Is there a benefit to getting a Power Vent unit vs. an atmospheric unit? I haven't priced the standard vent units yet, but I'm sure they are quite a bit less expensive. I will have to run a Class B gas pipe from the basement through the roof for the std. vent, but still.
For what's worth Bradford White is made in the USA and Rheem is made in Mexico. That's why I chose one when mine was replaced 2 months ago.
When I choose, Ill be getting an A.O. Smith or Bradford White, made in USA.
IMO, getting an atmospheric unit with as good efficiency as possible (0.63-0.64 is abot as high as they go), turning down the water temperature a few degrees and insulating all hot water pipes as much as possible is the best way t ensure low operating cost, along with simple, rugged, reliable service. Dont some of those fancier ones not work when the power is out?
JMH
I had a Bradford-White Propane burner when I built my house. Best darn water heater I've ever had.
With that said, the only reason for a power vent is putting it where you can't get through the roof or don't want a roof penetration.
BTW, I paid $300 for the 40 gallon WH and about $300 for installation of gas pipe and Type B flue through the roof in 1996.
Today, most residential mechanical contractors are getting $300-400 for any Type B vent through the roof, plus gas piping.
Tankless requires special venting and often a 3/4" gas line. I'm not convinced the savings is what it's cracked up to be. They also won't work if the power is out.
slightly OT
I have a 2 year old Bradford White 40 gallon water heater.
I had to shut off my water heater during the day while I was haivng some work done on the house. I'd turn it (and the gas line) off before leaving for work at 6:30 and turn it back on in the evening about 6:30 pm. When I'd turn it back on the pilot would light but not the burner. It took me awhile and a little disbelief to figure out that the tank maintained temp all day. with 65-70* weather it was holding 120* for 12 hours with no heat source and no add on blanket. it did that 3 days in a row. I think that is pretty danged effecient!
Too Slick,
I remember when I was single and would travel "back home" on Friday afternoon and come back Sunday evening. I would shut the (B-W) water heater off on Friday morning after my shower.
One Sunday night I forgot to turn the burner back on. I just left it on pilot.
I still was able to take a warm shower Monday morning after the water heater had been off all weekend.
Contrary to what some people say and believe, that burner usually doesn't kick on until there is a significant amount of water used from the heater.
I also like the Bradford White. It is well made and has a real brass drain valve. So many now come with plastic drain valves. I don't have the power vent model though.
I just bought an 80 gal Bradford White versus the 2 50 gal tanks most builders install (I have 3 daughters so hot water is a commodity here). The B-W does a great job and recovers as fast as you use it. We can take 5 showers & run laundry & the dishwasher and still not run that thing out of hot water. It's energy efficient as well.
Thanks for all the great replies. I couldn't believe the prices I was quoted for the power vent models. The reason I was looking at a power vent model was b/c I can put it anywhere in the basement. I don't have an easy place to put the standard vent w/h in the basement and be able to run a chase through one of the closets and up through the roof without any elbows.
I believe we may get a standard unit and put it in the garage. The kitchen & master bath are on this side of the house. However, the laundry room & other bedrooms are on the other side of the house. Heck, I can buy two regular w/h for the price of one direct vent. Mmm... maybe put one for the laundry room & 3 bedrooms side of the house and put one in the garage for the kitchen & master bath side of the house. That might work.
Also, I did like Bradford White b/c they are made in USA and seem to be a smaller company but yet produce a fine product. A.O. Smith owns everybody now except Lochinvar, BW, and Rheem/Ruud. They own Apollo and also State which owns Reliance which makes Maytag. They also bought GSW wich owns John Wood & American water heaters. It's sorta like the deep freezer market - not many real players, just a commodity I guess. Ah, the world of corporate in-breeding.
Make sure you do the vent calculation BEFORE you buy. And do install a 4" pvc vent line. Some jamoke plumber put a 3" line in my house and I had to tear the whole thing out before I put in the B-W. You also might consider adding a fresh air intake pipe into that room so you don't get negative air pressure when the burner comes on.
