Today one of my seasoned employees had a monumental mental lapse and filled one of our 26hp compact John Deere tractors with gasoline. He returned after a half hour of brush hogging (grass) and said it was smoking more than normal and the exhaust smelled unusual.
GRRRRR. This tractor is only 5 years old with about 600 hours on it...almost new. I'm guessing that the fuel mixture was about 60%-70% gas.
I know that the pump and injectors could be damaged. The oil might be diluted by gas if the mixture washed down the cylinders.....maybe piston/ring damage.
I will purge the fuel system, install new fuel filter, change the oil and filter....maybe do a UOA. Fire it up and pray.
What else can I do? What else to look for? IFFFF it seems to run o.k., should I have the JD dealer do extensive diagnostics on the components for verification? I'm paranoid that a small problem now might escalate slowly into failure over the next year on any of the components listed above.
Thanks for any advice.
I'm having a "Critic" week.
