Hello all,
I purchased a 42" MTD generic (Lawn Machine or something) mower with a 16.5hp B&S motor for $150. It cranked hard but started when I looked at it. I got it home and put a new plug and fuel filter in it, along with performing an oil change (Valvoline ML 10w30, sale + thickness = purchased). AFTER I got my new oil in it and the maintenance completed, I tried to start it, no luck.. It must have stopped part way through a "cycle" and there had to be a lot of vacuum in the head because gas began to pool in the carb, spilling everywhere, coming out of where the air cleaner should have been. I clamped the fuel feed hose, pulled the plug, and cranked the motor a few times expelling gas from the cylinder. I then went and purchased a new battery, and mowed my lawn. Approx 2 acres. I know I need to adjust the valves as it still cranks a little slow in one spot. I'm not sure there's anything anyone can tell me to re-assure me to the point of believing the oil hasn't been contaminated by gas, but please try. Please try! I mean, heating the oil from mowing for 2 hours could possibly have "boiled" off some of the fuel in the gas right? And I mean, I don't know anything about what oiling goes on inside mower engines, maybe gas wouldn't have got into the oil? Can anyone tell me something reassuring, or should I just buy another quart of oil? It was an atrocious process to change the oil, rather than neatly pouring out of a hole under the drain plug as I assumed it would have, it spilled onto the entire base of the mower, the deck, basically just poured out everywhere but the hole I had the pan under.
Thanks & have a good weekend
