Good idea.I bought 8 of the cheapest T4 fixtures from Home Depot, then bought the LED Tubes from Costco
Exactly!Good idea.
I would NOT buy fixtures that you can NOT change the bulbs.
As in, when the bulb stops working, you throw the whole fixture away.
You fellas mentioning to only get LED fixtures with replaceable "bulbs", those don't exist unless you buy incandescent or fluorescent fixtures to retrofit with LED lamps, which is kind of silly to do right out of the gate IMO.
i should have elaborated better. What I meant was if you are adding new fixtures, I don't see the point in installing a new fluorescent or incandescent fixture for the purpose of putting LED lamps in them. That is the only way you can have an "LED" fixture with replacable bulbs.I don't mean this in a confrontational way, just want to know why that would be silly?
I put 6 of these in a 2 car garage and it will give you a tan...Harbor Freight sells LED garage lights. 10,000 lumens at $49.99 each. Four tubes each light fixture.
I bought four. They can be daisy chained also. Really bright. I took my old lights, florescent fixtures, and mounted them around a perimeter so I could do car detailing in the garage.
https://www.harborfreight.com/light...amond-plate-led-hanging-shop-light-56780.html
I'm sure someone makes a lightning calculator. How many lumens from your current setup? Is that enough? What Kelvin temp are your fluorescent bulbs 4100k, 5000k, 6500k? I like between 5000-6000k fluorescent bulbs as if they are full spectrum create even natural colors.Two-car garage with 10’ ceilings. Desperately need to replace my two flouresent fixtures so that I can detail my cars. Recommendations for overhead LED setups?
At some point it seems like the color rendering index (CRI) should be upgraded or adjusted to reflect modern lighting. CRI (100) index has been based on incandescent lighting and 2700 degrees seemingly forever!I'm sure someone makes a lightning calculator. How many lumens from your current setup? Is that enough? What Kelvin temp are your fluorescent bulbs 4100k, 5000k, 6500k? I like between 5000-6000k fluorescent bulbs as if they are full spectrum create even natural colors.
