What games is he looking to play?My son has asked for a gaming PC for Xmas and I have zero experience in them. Budget is around $800. Any suggestions?
See if he would rather switch to PS5 or whatever is the latest. That’s more in the budget.My son has asked for a gaming PC for Xmas and I have zero experience in them. Budget is around $800. Any suggestions?
We are Xbox people, PS5 Pro will be out soon. Great recommendation.
Red Dead Redemption, Roblox, Minecraft, etcWhat games is he looking to play?
We are adding a 2TB internal memory stick to our PS5 for now., PS5 Pro will be out soon. Great recommendation.
I'm not actually a gamer but buy gamer PC's for my Engineering business because they are the cheapest way to get the most powerful machine.I'm seeing Cyberpower PC for around $800 and other brands. We don't need ultra power, just a good basis for which we can upgrade in the future if needed
This will make or break a gaming build.Whatever you buy make sure you either have an RTX4060 in it or a Radeon RX4600XT and your PC will not have any trouble playing any game at 1080p or even at 1440p, with reduced visual settings.
A 4060 will do just fine. And will be better with the upscaling tech than the 3060ti.This will make or break a gaming build.
avoid the RTX3050, it's a detuned 3060 and more a replacement for the discontinued RTX2030.
Even a 3060 is a lot better.
If you can get a 3060 Ti or 3070 Ti they are great value.
A 4060 Ti is the newer model and still reasonable, but after that costs get crazy.
NVIDIA has kinda stopped dramatically increasing performance with each generation so a 3050 is basically a 2030 replacement, same for 3060 and 4060, 3070 Ti and 4070Ti.
There are improvements but the primary difference is greatly increased cost.
EG I would take a 3060 Ti over a standard base 4060.
Since we're talking about GPU's I found a good website which has comparative performance based on many reviews and bench testing:I found a local guy building gaming computers in his basement, I told him what my son plays and the budget and he built a system with some new and used parts for $500 in a full size tower with a glass side panel, with push pull fans and the all important cool blinky lights on the video card. It seems to run everything well enough, and he plays mostly War Thunder and minecraft with his buddies which seem to take nearly nothing to run. He runs War Thunder pretty much max'd(removing some detail is better for playing) at 1080p and gets over ~200fps with a GTX1060 6gb
The idea was to get my son the basics and then he could upgrade it, but so far it hasn't needed anything.
Red Dead redemption seems to take very little to run either I read, so if you aren't going to play the games that need the newer GPU's, the old GPU's seem to play many games very very well.
A 4060 is a great GPU.A 4060 will do just fine. And will be better with the upscaling tech than the 3060ti.
I had an RX5600XT that played RDR2 without any issues at 50-60fps or Elder Ring.
This GPU is now in my son’s PC and he has no trouble playing his games.
I've never built a PC before but I have the skills to accomplish it.Do you or your son prefer a pre-built one or building one yourselves?
