G-05 compatabiity
Near the beach in Delaware
From Zerex:
The Zerex G05 formulation is 100% compatible with the conventional green coolant product. You may mix the two or flush the entire system with the G05 with absolutely no problems existing.
Does everyone agree?
Can I assume any G-05, not just Zerex?
Pete is correct. Here's the Ford recommendation (at the bottom):
http://fcsdchemicalsandlubricants.com/supplier/quickref/scuc.pdf
They basically say that if you don't flush the old green out very thorough, then you should follow the maintenance schedule of the GREEN coolant with your change to G05. .
I believe the Peak products have similar recommendations. You can mix and match, but to get the advertised longevity you have to do a complete flush of the old product first.
Originally Posted By: Donald
From Zerex:
X2 on the comment that if you don't COMPLETELY flush the system, you should follow the maintenance schedule for conventional coolant (personally, I do anyway- 5 years seems like WAY too long to run any fluid).
AFAIK, all G-05s are essentially the same (except for some reason, Ma Mopar dyes hers red when everyone else uses pale yellow). Zerex is certainly the most readily available unless you make a trip to a Ford or Mopar dealer.
FWIW, been using G-05 in my 66 Mopar 440 ever since the rebuild 3 years/27,000 miles ago. I popped a new thermostat in a few months back, and everything in there looked absolutely great. I know the HOAT coolants are primarily to protect aluminum and there is ZERO aluminum (well, the tiny little water pump flange...) in the 440 itself. But with a new aluminum radiator, it seemed like the way to go and I have to say so far so good.
