Originally Posted by dbias
i've experienced wildly different results btwn varied types of vehicles.
Nissan Pulsar FWD with manual transmission with all season tires would go anywhere in the snow. Drove to work one morning after an 18 inch overnight snow fall and literally pushed snow that came up on the hood in some drift areas.
F350 4x4 single rear wheel with all season tires as expected would go anywhere in the snow. Went weaving through several 4x4 Duallys on a really snowy and icy road. I suspect the dually tires didnt help them as opposed to the single tire i had in the back.
Mustang GT Manual trans RWD of course would only go in the snow if i went to the grocery store and filled the hatch area full of 40lb water softener bags then it was not quite as scary, weight over the driving wheels definitely helped.... kept the receipt and returned all the salt in the spring. ...‚
Audi A4 Quattro with DSG and all season tires.Haven't had any problems as expected. Nice thing about the Quattro system is if it is really bad out the Quattro system will keep all wheels spinning at the same time instead of the front tires spin, rear tires spin that some AWD systems do, (cough cough looking at you VW Haldex and others lol). By having all wheels spinning at the same time, all the time, it helps with traction, momentum, and predictability with steering inputs. The Quattro pulls so well there is a good danger in underestimating stopping conditions because as important as getting going is it is more important to be able to stop, which is where real winter tires help.
2WD duallys need massive weight in back to be anything other than useless in snow. My F-450 does OK, but it is around 12-13K & has a rear Eaton locker-it can do anything the 4X4s in the household can do in snow. Unless you have studded snows, weight over the drive axle is paramount in bad winter weather.
