**This thread will only apply to people that drive in snow and ice***
Some people believe in being cheap and only putting snow tires on the drive axle as that is what was done in the old days when they were growing up. All they had primarily was RWD rear wheel drive beasts which no doubt was not an issue, you just had to plan your stops better and pump the brakes. And quite frankly the traction was limited anyways with tires of that era. Cars simple weighed a lot and people adapted and im sure lots of people crashed too.
Fast forwarding directly to the point, I can reproduce it every time and cannot recover it very well. If you place 2 nice studded snow tires on the front axle of a FWD vehicle, and leave your all season tires on the rear, the back end will get loose on you when you let OFF the gas pedal. When you try to correct the issue or hit the brakes, it will make it worse. The only way to recover is to step hard on the gas and steer away to the direction you want it to recover. BUT.....if you are trying to slow down or stop for an intersection, this wont work either.
So.....we know the answer is to buy 4 snow tires and the problem goes away, but my question is simple, with good skill is there a technique to recover this oversteer condition and still get the vehicle stopped? Or will a modern vehicle with ABS or stability control prevent this?
