That looks way more complex than Bosch K-Jetronic which Mercedes kept on using until they transitioned over to LH-Jetronic/Motronic in 1992-1994.A 1965 Corvette 327 with Mechanical FI. Lot'sa problems with it, but who cares?
And they had lotsa problems. There is an expert just east of Sac who "fixes" them. My BIL's unit is there right now.That looks way more complex than Bosch K-Jetronic which Mercedes kept on using until they transitioned over to LH-Jetronic/Motronic in 1992-1994.
To be more precise I'm thinking of the Toyota Corollas that switched from carbs to EFI around 1990.Is this a purely hypothetical exercise or is it actually under consideration. If not purely hypothetical what car specifically.
A lot of older EFI is getting hard/expensive to obtain parts for (try to buy something for a an old L jet System)
I would (did) probably choose an old carbureted dinosaur with a modern injection system...
Honda still used a weird TBI-like system in the 1990s as well.To be more precise I'm thinking of the Toyota Corollas that switched from carbs to EFI around 1990.
Can you always fit an aftermarket EFI to a carb but never fit an aftermarket EFI to an original EFI?
In import “tuning”, there’s also the option of installing a AEM piggyback ECU and keeping the OE - the piggyback will take over fuel and spark, the OE will handle other things.You can certainly fit aftermarket EFI to an original EFI. See, for example, Megasquirt: https://megasquirt.info/
If it’s a simple carb like a Holley, carbs all day but it’s a lost art to service and tune ‘em.
GM managed to milk the QuadraJet until the 1990s when they introduced TBI/CPI on the trucks and their cars started to use MPI/SFI. Mercedes was last to use continuous mechanical fuel injection, K/KE-Jetronic until the 1990s as well, BMW and VW stopped using it in the early 1980s. That’s a testament to for the time “advanced” tech. All GM did was modify the Q-Jet with fuel/throttle control solenoids and Bosch tacked on a electrohydraulic actuator onto K-Jet.
You spelled edelbrock wrong.... leaky side bowls and blown power valves aren't my cup of tea lol750 Holley on a 327 with points. It will be running long after anything electronic got cooked in the war.
Well-said.I have way more issues over a long span of time with computers and injected rigs than I ever did my carb rigs
I wouldn't daily drive a classic, EFI or Carb.Hi,
Imagine the following:
You have the possibility to own an already 30 year old mass produced completely rust free car. The car is going to be your daily driver for the next 30 years and until then the car will be 60 years old.
But you have to make a choice: The car comes with either electronic fuel injection OR carburetors. Which one do you choose and why?
My point of view - although I am just guessing: The EFI is very very reliable as a daily driver in all conditions, summer and winter. The carbs will have more trouble and need more adjustments, tweeks etc. However, there is a chance that the EFI module will start to malfunction since 60 years is a looooong time for electronic components and buying a new module is almost impossible. A carb might need more attention but can always be fixed and repaired.
What is your point of view?
L
