OVERKILL
$100 Site Donor 2021
So these last few weeks, with the insanely cold temperatures we've been seeing, I've had two instances where the inlet vent on my furnace has frosted over, causing my furnace to shut off. In both cases this happened over night and we woke up to a house that was quite cold (13 degrees C). Took me a bit to figure out what was wrong the first time, but the warning LED on the furnace gave me a clue and I figured it out.
I have a power-vented natural gas furnace and a power-vented natural gas hot water heater. All exit the house on the same run of concrete, as does the inlet vent for the furnace. A quick glance at the manual for the furnace indicated that mine was configured incorrectly and some internet searching shows that this is uncomfortably common, despite furnace manufacturers giving some rather detailed instructions on how vent and intake are supposed to be oriented. The intake is supposed to be BELOW by 12" the exhaust so that when the hot exhaust exits, it doesn't cause condensate to frost-over the inlet screen, which is exactly what was happening. Here is what my install looked like:
Left-to-right: Furnace inlet, furnace exhaust, hot water heater exhaust. You can see how little snow there is around the pipes from the hot exhaust melting it.
Given the snow load we get, I opted for the "Alternate Horizontal Vent Termination (Dual Pipe)" configuration as indicated in my furnace manual:
With a 2nd vent added for the hot water heater.
The finished product:
However, I'm concerned about rain getting into the vents when the aren't in use and have considered putting small extensions on them with a 45-degree slash-cut, what do you folks think about that? Nothing long, maybe 2" or so?
Something like this, but not as hokey:
