Martyi,
Just one more thing, in regards to the washer Fumoto supplies. It is a composite washer and for some reason, my experience has been that they seem to tear, and then the fumoto drips oil. I don't think I am overtightening, but the composite washer came apart when I used it on my Mountaineer and on the Highlander last weekend. Both times I had fresh oil in and had to clean the oil catch pan, take out the fumoto and reinstall, then put the oil back in. A real PITA. The washer is hard, but both times when it ripped, it was soft after oil hit it. I did notice on the Highlander that the drain plug hole had a groove in it and maybe that ripped the washer. I installed the fumoto on the Mountaineer and Highlander without a washer, on my Acura and on the Ridgeline I used a Honda crush washer. Could be my issue, and I'm doing something wrong, but be careful of the washer they supply. If it leaks, taking it back out after you just put in fresh oil....well you know!
