Originally Posted by OilUzer
I was checking out some oils and read this on amazon:
"Castrol 06244 EDGE A3/B4 0w30 Advanced Full Synthetic Motor Oil"
Full Synthetic Oil
This oil is a full synthetic oil, meaning crude oil is not used in making it."
1. The terms "synthetic" and "full synthetic" are now totally without meaning in the context of motor oils. They are absolutely NOTHING except advertising drivel. There are ways to make informed conclusions about the make-up of an oil and its "quality" (however you choose to define that), but in no case does relying upon the presence or absence of the term "synthetic" help you decide whether an oil is good or bad, appropriate or not appropriate, etc.
2. That Amazon seller's choice of words reveals that he or she probably knows little about oil, except for how to regurgitate the meaningless marketing drivel someone else regurgitated at them. I don't know what that person does for a living, but I feel comfortable ruling out being a chemical engineer working for Castrol. . . There ARE ways to determine whether that oil meets your needs -- whether or not a seller called it "full synthetic" is NOT one of them.
Q:
can any engine oil be made with no crude oil? I thought that was not possible including even gtl.
Well there are the plant-based motor oils, but (and I'm just guessing here) I strongly suspect that the couple of blenders who actually sell this stuff to the public probably include some "traditional" oils in the product too.
Also, and I'll defer to anyone who's a petroleum or chemical engineer as to the definitions to be used here, but remember, virtually all the substances used to make motor oil can be traced back to a dirty hole drilled into the ground (or perhaps the seabed). Whether it came up the well still mixed into the actual "crude oil" or whether it came up in gas form, it came from the same place -- the bowels of the earth.
Full Synthetic Oil
Q:
