https://www.1010tires.com/ says the stock tire for the 1990 toyota corolla sedan was 155/80/r14, meaning the odometer was calibrated for this size.
so running a 175 70 14 tire would mean that i would of actually traveled around 3.76% more distance than what the odometer says since larger diameter tires cover more distance than smaller diameter tires per revolution.
https://www.tyresizecalculator.com/tyre-wheel-calculators/tire-size-calculator-tire-dimensions says that 165/80r14 revs 16 times less than 175/70/r14.
Would most of the fuel efficiency from the 165/80r14 tires be from the fact that it has a larger circunference and the engine revs less or from the 10mm less in contact patch?
what does a decrease in contact patch do?
