I have a couple of gasoline cans with these fabulous spouts that are supposed to keep fumes in. The spout has a sliding section with a shutoff valve built in and a locking collar. The idea is you have twist the locking collar, catch the edge of the spout on the lip of the tank you are filling, push to open and fuel pours out. It would work great if it weren't for the fact that the sliding section leaks copious amounts of fuel on the ground. So much for being "CARB compliant and EPA certified".
I'm tempted to just cut the collar off and see if I can glue the sliding section of spout so it's permanently open and doesn't leak. If anyone knows if there's an aftermarket spout I can use, that would work too.
