- Joined
- Jun 9, 2021
- Messages
- 157
I just bought an absolute dumpster fire of a 2008 BMW 335xi. After replacing two leaking injectors, I still have a slight idle unsteadiness and occasional misfire on one of the cylinders (not enough to set a code but I've isolated it with live data) which I assume is a fouled up injector based on the state of the others. It doesn't leak and it runs fine off idle. All new spark plugs and I've isolated the problem away from the coil pack.
I've used various fuel system cleaners in the past and haven't noticed any difference in how my car runs, just a feel-good preventative maintenance item. Everyone's seen the rave reviews for fuel additives and how they can cure all sorts of ailments, but of course, a lot can be chalked up to the placebo effect.
Personally speaking, have any of you ever had a verifiable issue (like an occasional idle misfire) that has been fixed with a fuel system cleaner? Should I just bite the bullet and replace this injector already or do I have a shot at salvaging it with something like Techron or SI-1?
