I have a 2007 Dodge Ram with a 3.7 V6. With a little over 120,000 miles. The plugs have recently been changed due to a slight misfire with no warning lights. I was told one injector was not pulsing when the mechanic checked it out, but recommended cleaning the injectors. It is working properly at the moment. Is it worth cleaning at this mileage or replacing? If replacing what brand? I see Bosch is cheaper than OEM Mopar branded units, but I’m not sure if flow rates etc are the same.
