Can an injector test okay(off the car) but still be playing up?
I have a misfire issue with my Toyota pick up(3RZ-FE engine), I managed to get it to the mechanics when it was misfiring.
It seems to do it if the truck is switched off when hot and then restarted 15 to 30min later.Any way it was misfiring on No 2 cylinder, they swopped 1 and 2 injectors around, it was fine for a while and then started misfirng on No 1.
So they removed the injectors and I sent them in for testing.
The company that tested them said the flow was slightly below spec but this would not cause a misfire, so I had them cleaned.
The mechanics reinstalled them and test drove the truck and said everything was fine.
I collected it this morning, everything was fine until again it was restarted after standing for say 15 minutes it misfired slightly on start up but then came right.
My question is can an injector test okay but actually be faulty when it gets hot etc?
