Originally Posted By: PhillyJoe
When engines had carburetors, we needed fuel filters. Now with FI, they figure one is good for the life of the car. I don't get it.
Fuel filters are even MORE necessary with EFI. But with EFI they can make a filter last a lot longer. How?
Well, EFI is regulated to at 40-80 PSI and the pumps can produce over 100 PSI. Carburetors operate at 3-8 PSI, and the pumps can produce... 3-8 PSI. As a filter clogs in a carbureted car, if it even causes a 1 PSI drop it can starve the engine for fuel. In an EFI car, the filter can clog to the point that it causes a 10, 15, or even 20 PSI drop and the fuel pump can still deliver enough pressure to the regulator so that the engine never notices the clogged filter. So you can run a filter a lot longer and get it a lot more clogged in an EFI car. Of course it makes the fuel pump work a lot harder, but the pump can do it... for a time.
Now if you also make the filter 30% larger than the filter in a carbureted car, its clear that you can (probably) make it last WAY beyond the warranty period- at which point the carmaker could care less if you ever change it again. Even more to the point, the PUMP will probably fail before the filter plugs solid (even if its due to pumping against a badly clogged filter) and they know you'll replace the pump and filter as a unit and you'll never know or care that the filter CAUSED the pump to fail.... :-/ Just another step on our march to being a disposable society.
No fuel filter is really "lifetime" unless you plan on throwing the car away when the fuel filter clogs. Me, I'd rather get dirty and drop the tank and change the filter than buy a new car.
