""So I'd say generally speaking, a higher quality oil will be better at resisting fuel dilution. One that uses stable VII and a good base oil. My worthless 2 cents.""
You can not get more stable than NO VII as in my second test on base oil alone. And it still thinned as much as the VII 10/30 which used a SSI of 35, VII which is a pretty good one.
Also
""most PCMO's use very cheap VII because the oils are designed to shear to meet better fuel efficiency standards.""
I do not know this to be fact I do not blend that way.
bruce
Also
bruce
