Should I should do my oil changes more often with using E40 - E50 in general in my tuned F150 5.0? I plan on doing my first UOA soon and I’m debating on the mileage to do it.
With a tune and ethanol I would be changing at 5k intervals max. Port injected EJs on ethanol I did 3k. A used oil analysis would give you the ability to stretch it further, but you aren't looking for extended drain.
Pull in-service sample when you get to a set mileage (say 5k) and send it to a lab with quick turnaround and that uses gas chromatography to determine fuel content. Then, based on the results of how the oil itself is doing (presence of contaminants, fuel >5%, iron ppm >150, TBN <2.0, or oil is out of grade on the low side) decide whether to drain or continue on. Based on how much “cushion” is left on those condemnation points, then pick your next sample mileage. Some results may have you try another 5k on top of the first one; other results may be 2k or so. This way you can find out where the “sweet” spot is.
FWIW, I ran my ‘19 F150 3.5EB on E30 for most of the 14.4k miles in my last sample, and the oil I used still had plenty of TBN and all other metrics were OK. I ended up draining it at 15.9k because the oil had thickened into a 40 grade.
