TallPaul: Oh, I researched this first, never-you-fear! The '86 manual calls for 30 or 10W30 in my climate, but I have used 15W40 for the past 20 years almost. Five years ago I lived in a much hotter climate and the 15W40 was more appropriate. I guess you could say that I'm in an overlap area here where both fit in the climate range, but the 10W30 is better in the winter range. This is somewhat an experiment, the ultimate goal being to aid lube flow on cold starts, and starts in general, and for MPG (all ala the Doc Haas "thinner is better" philosophy). I'm confident it won't eat the motor, but the UOA will tell the tale over the next year. And whatever tale it tells, I'll tell YOU! No ego stake in the results at all!
As to the gauge, I had forgotten that aspect of Fords... but concede your point. On mine, it does vary somewhat but moves very slowly from high speed operation down to idle on a warm engine. I had a mechanical gauge in it some years ago, but it blew the line in the cab. I had an "Exxon Valdez" moment that I can still find evidence of 10 years later. I replaced the gauge with a voltmeter. The wife's slacks went into the trash... ahem! I probably oughtta install a "real" gauge. But it will be electric!
I'll stick with Rotella, thanks! Had outstanding used oil analysis with it (or Delo) in all my equipment and I can usually buy it cheaper than MC to boot. Besides, isn't MC "Dictator Oil" (Conoco)?
