A neighbor gave us a free car! Its a first car for my GF's son who is about to get his license. 03 Maxima gle w/140k on the body. Used engine swap 40k ago, unknown miles. It runs (with a jump), moves. Sounds ok, no rapping. No CEL's. Low on oil, transmission fluid brown, etc. Will get to that. after I figure out why it won't hold a charge.
The story is the battery eventually loses charge, engine dies. Won't start unless jumpered. Runs for a bit, dies. The PO put in a new battery (looks cheap) and the new battery failed to hold a charge. He disconnected negative, car died instantly. Assumed its the alternator and gave up on the car.
Is disconnecting battery while running an accurate alternator test in a fairly modern car? I was going to try testing volts at battery while running to see if alternator is working so I had a battery tender junior on the battery all night. Still red (charging). Maybe the tender junior can't charge a car battery? Works good on my tractor..
All the fuses look ok..
The alternator is buried underneath engine so its not an easy swap. Probably why the car was given up on. Is it really the alternator? Or just a cheap [censored] walmart battery with 540 cranking amps thats not enough for the car.
Is this some kind of parasitic drain/ground problem known by Nissan owners?
Where to start? Any input would be helpful
