I’ve had the same problem several times. Had to remove the burr with a pick.Their threads usually have a burr on it too. I just bought one recently to look at the quality and the thread are poorly made with a large burr. This was on an Endurance
I asked him if I should, but he was of the mindset we shouldn't have to. Guess there is a perk of buying these in store, pre inspection.I’ve had the same problem several times. Had to remove the burr with a pick.
You did the right thing for sure. Mine was in the threads and I was so nervous some may have fell into the filter. I inspect everything before purchase now.I asked him if I should, but he was of the mindset we shouldn't have to. Guess there is a perk of buying these in store, pre inspection.
They should be able to track it by the date code on the filter's can.He made it sound like they have some ability to track batches, but there isn't anything on the filter to indicate the batch.
Unfortunately they were all terminated as a cost savings measure. Paying someone a salary to then be told that you're doing a crap job and need to scrap products, maintain equipment, and improve practices? How horrifying.Why pay someone to tell you to scrap product when most of the failures aren't likely to cause an issue and are tough to prove?Poor quality finish. Not the first time I've seen it. It's up to the people that are being paid to prevent this stuff from ever reaching the consumer.
No date code on these.They should be able to track it by the date code on the filter's can.
There should be. Counterfeit perhaps?No date code on these.
Not sure, CS rep told me there wasn't anything on the filter to determine it.There should be. Counterfeit perhaps?
You said you bought these as a 6-pack from Walmart. I'm thinking it was a 3rd party (not Walmart directly) selling through Walmart on-line?Not sure, CS rep told me there wasn't anything on the filter to determine it.
Directly from Walmart. I offered to read any codes off the filter, but the CS rep stated there wouldn't be anything printed on the filter they can use to track back to a batch.You said you bought these as a 6-pack from Walmart. I'm thinking it was a 3rd party (not Walmart directly) selling through Walmart on-line?
All the Ultras posted here in this forum have a date code, so something is up.
I'd think if Fram had the date code they could certainly trace the filter back to a lot or batch, probably even the production line it was made on. Fram is being inept it seems to me.I offered to read any codes off the filter, but the CS rep stated there wouldn't be anything printed on the filter they can use to track back to a batch.
I wasn't going to challenge FRAM on their own process, so these are now returned.I'd think if Fram had the date code they could certainly trace the filter back to a lot or batch, probably even the production line it was made on. Fram is being inept it seems to me.
